- 21 Sep 2025, 12:35
#75585
Un último detalle, que he leído en el foro australiano coffeesnobs, y me parece el dato más importante hasta ahora porque despeja la gran incógnita detrás de este molino.
Del Q&A oficial:
Es todo demasiado perfecto, seguramente me explote el que me llegue
Del Q&A oficial:
Vamos, que Option-O confirma que es compatible con las muelas del EG-1 y que ahora también montará Zerno Z2. Oficialmente confirmado.Q: What are the burrs options available for the LAGOM P80?
A: At launch, it comes with Mizen 80mm Omni burrs (80OM). These are versatile, providing brews and espresso that are sweet, juicy, and with satisfying finish - in our experience, excellent for both espresso and filter and they are likely the only burrs you’ll need in most use cases.
The P80 also has a flexible burr mount that works with 3-pin blind-burr mount (EG-1 style) and two-screw burrs, so you have the option to experiment with other 80mm burrs if desired. That said, if you’re just starting to explore different burrs, the 64mm burrs may be a better platform, since it has wider burr availability/support and is a more cost-effective ‘playground’ for experimenting.
- By VicenteV
